Green mouldy stuff in window edges.
Wilxay
Post by Wilxay »
Has anyone else experienced this with their 9 month old polo?!
I cleaned this car VERY thoroughly only 6 days ago (wheels off, wheel arches, polished and waxed)
helloimjammie
Post by helloimjammie »
I'm dreading getting this! Seen it happen to a few cars, I think its moisture build up, must a way to clean it?
Wilxay
Post by Wilxay »
It just makes my car look unloved which I can assure you is far, far from the truth.
AJ_7
Re: Green mouldy stuff in window edges.
Post by AJ_7 »
My Polo is coming up to three years old, it has been cleaned religiously and I have the same problem. I'm still undecided whether I'm going to ask my local dealer to replace the seals under the manufacturers warranty or not as I don't think they should be going mouldy after three years. I would normally just ask for them replacing but once you start messing around with seals you are opening up a world of pain with future wind noise etc...
AJ
ben4012
Post by ben4012 »
This is not a warranty issue. Just clean it off.
Wilxay
Post by Wilxay »
I think I agree with you Ben but why would it form if I don't go three weeks without cleaning it?
AJ_7
Post by AJ_7 »
ben4012 wrote:This is not a warranty issue. Just clean it off.
Clean it off with what? I've pressure washed it off a few times, the more you clean it the worse it gets. It is mould after all which grows in areas of consistent damp so cleaning it off is not a solution.
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
It's mot mould... It algy.
ben4012
Post by ben4012 »
With whatever works, a brush, a cloth, a fingernail. Either way don't let it get you down.
skipster
Drives: 2010 GTI
Post by skipster »
Yes - I have got this on our GTI, I have just left it to be honest.
chrispy.
Post by chrispy. »
I have got a tiny bit forming on mine, and am getting a squeek from the window
Will be cleaning this right off!
It is the price you pay for living in a country with lots of wet weather and maybe clean air! Unless VAG impregnated all external "rubber" seals with something nasty, this will always happen to cars left outside - I tend to garage my cars so get none of that at all.
Wilxay
Post by Wilxay »
This isn't forming on rubber it's forming on felt. And I've only noticed it forming since this time last week when I give it a deep clean.
Roundsquare
Post by Roundsquare »
Ive always thought it was fall out from trees.
I did get it on my wifes Suzuki but by using G101 it cleaned it up and its never come back.
Sent from my GT-I9305 using Tapatalk
Wilxay wrote:This isn't forming on rubber it's forming on felt. And I've only noticed it forming since this time last week when I give it a deep clean.
Yes, but that "felt" is really plastic/rubber with a bit of added "feltish" synthetic material on/in it.
