help needed!!
help needed!!
Just bought a 6n it idles up to 2000 revs itself until the clutch is released then goes back to normal also tries to cut out about 3 qwarter throttle but if you floor it it doesny do it Really annoying any help apprecited with pics as im new to the volkswagen :p
Re: help needed!!
Forgot to mention my temp gage does not move at all is this all related to the temp sensor ? Dont want to start stripping it down if its somthing simple may start a project thread if a get these problems sorted
Re: help needed!!
You'll def need a new temp sensor. That won't help things and can cause all kinda of idle starting and cutting out related issues
Be sure to get a genuine vw one as copy ones are poor quality and don't last.
Re: help needed!!
Wouldbthis cause the car to try and cut out when the pedal reaches a certain point then burst into life if a lift off or press more ?
Re: help needed!!
It can do. It's plays a big part in the air fuel ratio and if it's failed it'll cause over or under fuelling
Re: help needed!!
Ill replace it thro the week n see what happens it could prolly do with a good service to
Re: help needed!!
I got a new sensor and changed it over seems to have cured the problem how many sensors should I have as theres the temp and then theres a hole for another sensor thats blanked off but all the other polos ive seen have had 2 So am I missing 1 if so wits it fur
Re: help needed!!
Some have one some have two. Depends on age and engine
Re: help needed!!
Awell think its sorted now thanks
