[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Removal of roof lining. - UK-POLOS.NET - THE VW Polo Forum
Need to gain access to the roof mounted aerial..
Anyone have a guide to removing the lining?
I believe ill need to remove the plastic trims either side, but dont know how to
You can just remove the rear trim on the back of the rood lining and squeeze a spanner 24mm to undo the bolt if not all the a,b,c pillar trims are clipped in and can just be pulled out the grab handles maybe bolted in if not they are just clips the need a screwdriver inserting and pull the grab handle out.
