Mystery pipe
tlines559
Mystery pipe
Post by tlines559 »
I'm new (and generally uneducated when it comes to cars) so sorry if this is a really dumb question! I just changed the air filter on my car and noticed this hose has a crack/tear. Image
What is this hose for? Does it need replacing or will taping it be ok for now?
Re: Mystery pipe
It's the crankcase breather Hose. Really you should replace it or it could smell fumey in the car
Your local vw dealership can order one in for you
tlines559
Re: Mystery pipe
Post by tlines559 »
That's great thank you! I've just rang them and they said it would be £34.38 if anyone was interested!
Do you think replacing it is something I could attempt or be better off to admit defeat and hand it over to someone who has a clue? I want to do as much myself as I can and I want to learn but equally I don't want to mess up something important!
Re: Mystery pipe
That pipe is easy enough to change
It just pulls off the airbox on the top, then a firm pull will release it at the bottom (its only about 6 inches long)
It goes into a T joint at the bottom, so support the T joint underneath as you pull it as you only want to remove the top short hose!!
When refitting, soak the end for the T joint in boiling water for 5 mins to soften up the rubber which will make it easier to push it back onto the T joint
Does that make sense?
tlines559
Re: Mystery pipe
Post by tlines559 »
That makes perfect sense, I'll give it a bash when I get the new hose, thank you for your help! Worst case scenario is I can't get it back on and I'll just run to my next door neighbour who owns a garage. Thanks again
