Removing vw badge from r line grill
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
Post by greypolo9n3 »
Is removing the VW badge the same as old ones?...twist off?
Or do i need to have the grill off?
Re: Removing vw badge from r line grill
Removing
Carry out following work:
– Press trim -1- out of upper bracket -arrow a- with a screwdriver -3-.
– Pull trim -1- upwards at an angle -arrow b- out of lower bracket.
– Press upper locking hook -3- together with a screwdriver -2--arrow a- and prise out of radiator grille -5--arrow b-.
– Pull emblem -1- with both lower locking hooks -4- upwards at an angle -arrow c- out of radiator grille -1-.
Installing
– Insert emblem -1- with locking hooks -2- into recesses in radiator grille -3--arrow a-.
– Turn emblem in -direction of arrow b- until locking hooks -2- engage.
– Insert trim -1- downwards at an angle -arrow a- into lower bracket in radiator grille -2-.
– Press trim -1- into upper bracket -arrow b-.
Joe9n3
Post by Joe9n3 »
Just twist it, seperate it off the car if need be
