Hi everyone,
Hope you can help me here as I'm completely stumped by this problem.
My Polo 9n 1.2 E has developed a starting problem which only happens after it has been sat overnight. When i first start it up it will struggle to start and sometimes completely stall. If i put my foot on the accelerator it wont stall if i give it sufficient revs but I've never used to have to do this.
Once i start the engine again it will run fine and throughout the day. I can stop and start it fine after this but the problem comes back again once the car has been sat for a good few hours.
I've plugged in a cheap OBD2 scanner and it shows no codes or problems.
My car has done over 130k miles and its petrol.
Had new starter motor and battery 6 months ago (this was before the problem occurred)
Just had an oil & filter change. (This was after the problem occurred)
Would appreciate any help and if you need any more info let me know!
Many Thanks
Luke
Polo rough start sometimes stalls but then runs fine?
Re: Polo rough start sometimes stalls but then runs fine?
As it is a cold start problem, maybe replace the engine coolant temperature sensor, cheap and easy.
Fixed it !
Decided to change the spark plugs, whilst doing this i noticed this small hose had a crack in. Started the engine and without the polo cover on the engine stalled straight away which i thought was the plugs at first.
Turned out everytime you moved the hose with the crack the engine would struggle then eventually stall. Replaced and its running fine.
Thanks anyways guys !
Ishan8764
- Drives: Polo 1.2 mpi 2010
Sir i need ur help same problem with me no mechanic could find out the problem
Batchdn
- Drives: 1.2 match 2011
Mine has been doing this recently and the mechanics can never fix the issue
