How to turn on heated door mirrors?
nry
Post by nry »
I'm a bit confused, my 2014 BlueGT supposedly has heated door mirrors, and the adjuster dial on the drivers door has a heated symbol on it, but how do I turn them on?
Nothing seems to light up to tell me they are on, do they come on with the rear screen perhaps? I tried clicking the adjuster dial up to the heated symbol but again nothing looks to happen?
The owners manual makes no mention of them that I can see unless I've missed it :)
Thanks,
Chris
wolfie
Re: How to turn on heated door mirrors?
Post by wolfie »
I think it's just a matter of setting the knob to the heated symbol and turning on the heated rear window. Pretty sure they're linked. That's what 've been doing and it seems to work OK.
CrypticG
Drives: 1.2 TSI SEL (6C)
Post by CrypticG »
Same as Wolfie - although I don't click the heated rear window on with it. I just flick the dial and it works a treat, but I see what you mean with no symbol or dashboard light.
The only way to know that heated wing mirrors works is putting your hand over the glass mirror. Image :lol:
Surely, in the VW Polo 6C (in the CAR menu) can be linked to the heated rear window. In the 6R, linkage through vagcom is needed.
In this way works automatically with the temperature parameters set at the factory.
nry
Post by nry »
Ah so you turn the heated side mirrors by turning the adjuster dial to the heated symbol, makes sense!
lancslad1985
Post by lancslad1985 »
Just flick the dial round to the symbol and job's a good 'un. Just don't forget to turn them back off or you might see your economy suffer!
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
I have used VCDS and coded my BlueGT so the heatet mirrors turn on when I turn on the rear window.
By doing that you automaticly disengage the option to turn it on via the window switch and it then only works along with the rear window.
A much better solution in my opptinion. And works brilliantly. :)
Tooks
Drives: 2011 Polo GTI
Post by Tooks »
Mart!n-GTI-DK wrote:I have used VCDS and coded my BlueGT so the heatet mirrors turn on when I turn on the rear window.
I've done the same, a much more sensible arrangement.
CrypticG
Post by CrypticG »
Tooks, have you got a 6C?
Tooks
Post by Tooks »
Sorry, no, I've got a 6R GTI and a 6R 1.2 TDI, and I've done the same mod to both via VCDS.
CrypticG
Post by CrypticG »
Tooks wrote: Sorry, no, I've got a 6R GTI and a 6R 1.2 TDI, and I've done the same mod to both via VCDS.
ahh ok, i was hoping you had the cable and software for the 6C - so i knew which i needed as there are loads of variants.
Tooks
Post by Tooks »
I have HEX CAN+ cable and VCDS and I'm pretty sure that's the cable you need.
All VAG cars since about 2004 have used the same interface and protocols, and I don't know why they'd change it for the 6C.
Safest way (for a genuine cable anyway) is to email a reseller like Gendan Here in the UK and tell them what car it's for. That way, if for some reason it doesn't work, you can return it.
CrypticG
Post by CrypticG »
great, thank you very much - i will do that on Monday :D
Mart!n-GTI-DK
Tooks wrote:All VAG cars since about 2004 have used the same interface and protocols, and I don't know why they'd change it for the 6C.
Because they don't want amateurs f*****g their programing up.
Tooks
Post by Tooks »
:lol: quite possible I guess!
