How can I remove the seats and rails properly?
Wanting to give the inside a proper clean.
Things such as disconnecting the battery or whatever?
What screwdriver will I need? how do I disconnect the wire under the seat?
Front seat removal?
Re: Front seat removal?
Also known as an M10 Spline bit
Thanks Alex...you know...
Thanks for the help but I don't completely understand - It tells me to connect airbag adapter although I am removing the chair?
Logically.
The airbag is into the seat and can explode (electrostatic) while the seat continues disassembled.
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Is it possible for you to think that the Connect part refers to when you install the seat?LeeT96 wrote:Thanks for the help but I don't completely understand - It tells me to connect airbag adapter although I am removing the chair?
Since the guide is called removal AND installation of front seat... It is okay to think logical when working independtly.
