Are these plug & play?
chrispy.
Post by chrispy. »
Hi!
I have seen these Climate Control panels on this website and wondered if they are Plug & Play?
I currently do not have Climate control so the word "Upgrade" throws me off a bit.
I have the 087 BCM in my TSI
http://www.carsystems.pl/displays-and-c ... l,c54.html
Secondly, which one will fit my Polo 6R TSI?
Thank you!!!!
Re: Are these plug & play?
No. The automatic air conditioning is a completely different system. The entire air con system would need replacing.
TheFrog
Drives: 2015 Blue GT
Post by TheFrog »
alexperkins wrote:No. The automatic air conditioning is a completely different system. The entire air con system would need replacing.
I have just had the manual control unit in the dash of my 2014 Ford Transit Custom replaced by a new automatic climate control unit and it works fine. The dealer only swapped the dash-mounted control unit, nothing else. It must be a completely different setup in the Polo.
chrispy.
Post by chrispy. »
Had a feeling it wasnt going to be simple :)
Thanks Guys!
Mayhem
Drives: 2010 polo 1.2 tsi
Post by Mayhem »
Is there wiring in place for it to be connected in the polo? I know in fords they generally put all wiring in place for all the extras but only dropped things like fogs and climate control in if you had upgraded spec levels etc
Vw used to but in recent years they've stopped doing it and do a different loom for each setup to save on wiring costs
