Cooling System
Nathan I Think
Drives: 6kv5 1.9 tdi
Cooling System
Post by Nathan I Think »
Hi all im new to the forums and recently bought a 1.9tdi 6kv5 polo. The estate one. quite impressed for 500 buy has a few issues. First of all is the cooling system. I have bled the system to get all the old coolant out just looked like rusty water, i thought this was the cause of the cold heating issue. the issue is still there does anyone have any tips for bleeding the system. i have flushed everything out inc the heater matrix. the second issue is the driver side electric window doesnt work. i know the switch works but nothing happens. Any help would be lovely
Cheers NAthan
Re: Cooling System
Welcome Nathan
Coolant can sometimes look like rusty water depending on what additive is used
The system is generally self bleeding. But you can force it by taking the expansion cap off, and squeezing the big rad hoses whilst the engine is running. You may need a new thermostat if you havent got any heating.
Is the engine getting up to temperature?
Does the heater ever get remotely warm?
Nathan I Think
Re: Cooling System
Cheers and yes, i have checked the hose coming out of the thermostat housing and it is warm so the thermostat is warm. nope the heating never gets warm and the car sits at temperature just fine cheers
NAthan
Nathan I Think
Re: Cooling System
hi the heating never gets warm. i did 150 miles yesterday. she didnt overheat and stayed at a nice temperature but still the heating would not get hot. Cheers
Nathan
Re: Cooling System
Ok so it could be one of too things
Its either -
Heater matrix is blocked
The thermostat valve on the heater matrix is broken
How much resistance is there on the hot/cold dial inside the car?
Nathan I Think
Re: Cooling System
hi thanks. i have changed the thermal resistor aswell. theres not that much resistance on the dial either. could it of come detached. i have checked the back of the dial and the cable is on. dont know about the other end tho cheers
Nathan
Nathan I Think
Re: Cooling System
hi there inst much resistance on the dial but i have checked the cables on the back and when you turn it to cold it does speed up so im assuming that its okay. cheers Nathan
Re: Cooling System
It would be worth checking the lever at the other end of the cable to make sure its actually opening and closing the valve
Nathan I Think
Re: Cooling System
Okay will check that when I get some time. Coming to work this morning if I leave the fans off but the heater on full and then turn the fans on a few seconds of hot air come out then back to warmish
Cheers Nathan
Re: Cooling System
Sounds like a blockage/valve isnt working for sure then
Nathan I Think
Re: Cooling System
cheers for the reply. i have just a another look and the valve is definitely moving and both the pipes running to the heater matrix are hot.
cheers nathan
Re: Cooling System
Youve got a blocked heater matrix then by the sounds of it buddy
Nathan I Think
Re: Cooling System
ok i thought if both the inlet and outlet pipes are warm then the should be warm heat or could part of it be working and part blocked?
Re: Cooling System
It depends. Heat can transfer both ways remember even if the water isnt flowing that greatly.
Is your cabin air filter clean?
Nathan I Think
Re: Cooling System
ahhh okay i didnt know that bit cheers and yeah it looks pretty new cheers
