Stereo issue.
gary390
Drives: 2011 SEL 1.6
Stereo issue.
Post by gary390 »
Just installed the RNS 315 my problem is that the stereo doesn't turn off when I turn the car off nor does it turn on when I start the car up. I have have to press the power button to turn off and on!
What can be done about this?
Sent from my iPhone!
gary390
Stereo issue.
Post by gary390 »
Any ideas?
Re: Stereo issue.
That implies the CAN bus isnt online for the RNS315
Check that its coded properly in VCDS, but first of all, check its plugged in properly and nothing is loose on the wiring plug.
gary390
Stereo issue.
Post by gary390 »
There isn't loose wiring I put my old stereo back in and that started up when I start the car and off when I turn the car off.
So I need a new can bus?
Re: Stereo issue.
You may have a faulty rns315. You need to see if you can contact it on vcds
gary390
Stereo issue.
Post by gary390 »
Once I connect it to that. What shall i do?
Re: Stereo issue.
See if you can connect to the radio and then check for fault codes
robertsm66
Drives: VW 1.2 TSI
Re: Stereo issue.
Post by robertsm66 »
What stereo was in prior to the upgrade ? RCD310 ? Did that work fine ? and turn on and off correctly.
The RNS315 is a straight upgrade and will work without any coding or modification.
Have you hard reset the unit ?
VCDS will show you any faults but also check adaptation (I'm not sure of any crazy options there maybe).
gary390
Stereo issue.
Post by gary390 »
Yeah there was a RCD310 in there previous. That worked all fine.
How do you hard reset the unit?
Not only does the unit not turn off or on with the car but the lights don't illuminate in the stereo when I turn the side lights on. So I should just get it hooked up to VCDS and go from there?
robertsm66
Drives: VW 1.2 TSI
Re: Stereo issue.
Have you slotted the RCD310 back in just incase a wire or pin has come loose ?
I'll look up the hard reset and come back to you.
Re: Stereo issue.
Its definately a can bus issue if the lights dont come on either
