Polo 6r flat bottom steering wheel
Is it possible to fit a Vw flat bottoms multifunction steering wheel to a polo 6r to work with a rns315
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Re: Polo 6r flat bottom steering wheel
welcomeL16MSP wrote:Is it possible to fit a Vw flat bottoms multifunction steering wheel to a polo 6r to work with a rns315
http://www.uk-polos.net/view ... 71#p421709
+1Mart!n-GTI-DK wrote:Yes.
Thanks is it a hard job would I be better of letting a professional do it or is it easy to do myself
robertsm66
- Drives: VW 1.2 TSI
Depends on your vehicle and it's spec. The swapping of a steering wheel is simple with the right tool.
Airbag removal is always exciting and really should be performed by a professional, however I've swapped mine over of several cars and vans 20 - 30 times with no issues.
Just make sure you disconnect the battery first and leave for 10mins before ripping that airbag off !
Which model vehicle do you have ?
Do you have VCDS ?
Do you have VCDS ?
