How do you get to the bulbs in the roof lights?
TheFrog
Drives: 2015 Blue GT
Post by TheFrog »
I want to change the 'yellow' bulbs for some nice LEDs, but can't see how to access the front or rear roof lights. There doesn't appear to be any info in the manual, either.
beatty599
Re: How do you get to the bulbs in roof lights?
Post by beatty599 »
i took a small screwdriver and went very carefully for the front dome, the sun visor ones you can just pull out and the rear ones its best to use a small screwdriver again
TheFrog
Post by TheFrog »
Ok, thanks. I'm half way there - did the sunvisors and removed that big curved bit of plastic in the front overhead console, but I can't see where to insert a screwdriver. Does the entire black housing come away, or do you remove just the clear plastic lens parts?
TheFrog
Re: How do you get to the bulbs in the roof lights?
Post by TheFrog »
^Thanks, Ciclo :)
I must try to remember to look at that site first :oops:
yw :wink:
Image :mrgreen:
George417
Drives: 6c Polo Gti
Post by George417 »
I used one of those window suckers to pull lenses off
