GT Cam swap 1.0 AER - Help!
Zimtimtim
Drives: 1.0 AER Polo
Post by Zimtimtim »
Hi all,
Ive installed a GT cam in my 6n AER and theres a great thread that Jarno did a while back but i have an AER and im not able to time this up.
I m using the standard sprocket and have seen guys setting this to 3-4 teeth back. But this is not possible from what ive done. I set the cam and then set the crank but the pistons hit.....
Please help! Jarno oh Jarno where art thou.....
Re: GT Cam swap 1.0 AER - Help!
You might be better to ask on polo3 as this was a common mod on the mk3 polo
When I fitted a GT cam to mine i timed it to TDC and checked it with a timing light
Zimtimtim
Post by Zimtimtim »
I can do. It is a mk4 though and surly this is also a common mk4 mod too
TDC the pistons touch. I did it too minus 5 teeth and it runs really rough
