Engine oil capacity
Engine oil capacity
Very quick question..
Doing a engine oil swap next week.. Will 4 ltrs be enough?
Is it 3.7 ltr for engine oil and 4.2ltr with oil filter?
Tooks
- Drives: 2011 Polo GTI
Re: Engine oil capacity
Depends on the engine?
It's also in the capacities section of your handbook if you want absolute confirmation.
As above depends on which engine u have, think it was 4.5ltrs for my 1.6
Are you not changing the oil filter? I would especially at 6 quid for a filter, remember to take the filter out before draining the oil if ur swapping the filter
I have the 1.2 TSI
Ive checked in that section and it didnt mention it
I am changing the filter, it's just the oil comes in 4ltr bottles so concerned if that is enough.
Maybe try looking on an oil supplier's website, like Oipe(sp?) or Opie Oils, they tend to list oil type and quantity - if you are lucky.
Ah, maybe ignore my "wonderful" advice offered above, the 1.2TSI info does not exist yet on that site!
Engine oil capacity
Bump
Is it not listed in the 'technical' book in the handbook pack? Normally the oil capacity and coolant capacity etc is all detailed
Ive had a look through the manual and supplement book but couldnt find anything.
Thats very strange. Its almost always listed.chrispy. wrote:Ive had a look through the manual and supplement book but couldnt find anything.
Anyway:
Engine oil
Caution
The oil capacity has been revised for engines manufactured from June 2011
The engine oil level must always be checked with the dipstick and adjusted as necessary → Fig.
Oil capacities
Engines to May 2011: with oil filter 3.6 l
Engines from June 2011: with oil filter 3.9 l
Thanks! Ill have a look tonight in the books i have in the wallet.. See if im just being silly.
Thank you!
Thank you!
See above - just included a quote out of elsawin which should be accurate
Amazing! Thanks so much Alex!!
