Driver side window issue
grem
Post by grem »
All of a sudden my driver side window will not go down by double clicking the window button down, so I can only do it by manually holding down the switch myself.
Passenger works fine so I was wandering if anyone could tell me what the problem is.
Also neither windows will go up by holding the lock button on the key, or down when unlocking the car.
What parts do I need if anyone knows?
cheers
IZVVC
Re: Driver side window issue
Post by IZVVC »
This happened to me briefly, but then fixed it self after a few days, I couldn't figure out what the issue was tho
Parts you need:
One finger. :lol:
What should you do?
- Window closed.
- Release the switch.
- With the window closed, press the switch up and hold for 3 or 4 seconds. (if you are attentive you will hear a click next to the speaker).
Repeat this as many times as necessary until set the comfort function.
Check for proper operation. :)
grem
Post by grem »
Thankyou so much ciclo haha!
I had no idea it would be that simple, it only took once and now its working fine again.
