[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Changing Air Vents on the Polo - UK-POLOS.NET - THE VW Polo Forum
The side vents simply slide out. Take off the side panels and you can push them from behind. To get he centre one off you need to remove the radio trim and then you can pull it off
