Polo gti coding help
Longman
Drives: Polo 6r gti
Post by Longman »
I own a 61 plate gti
I've tried to code today coming home lights and leaving home lights
Front fogs as drls
Needle sweep
Ticked the boxes in vcds but nothing worked
Any ideas ?
Here is copy of my scan on vcds
Saturday,13,June,2015,10:18:56:03480
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
http://www.Ross-Tech.com
VIN: WVWZZZ6RZCY503706 License Plate: POLO GTI
Mileage: 47420km-29465mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZCY503706 Mileage: 47420km-29465miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE) Labels: 03C-907-309-V1.clb
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 56341 001 1048576
ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
ROD: EV_ECM14TSI01103C906027AR_VW25.rod
VCID: 71E2D596A0A482A9911-8024
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-927-769.lbl
Part No SW: 0AM 300 052 B HW: 0AM 927 769 D
Component: GSG DSG AG7 421 2711
Revision: 00042014 Serial number: CU501105245880
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 2A5002FA86F2B17110B-5120
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230248E3416D02B5C42C12E282D740811700
Shop #: WSC 00788 648 00255
VCID: 07169B4EB220AC192F5-8052
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 3
Reset counter: 98
Mileage: 47217 km
Time Indication: 0
Date: 2015.06.05
Time: 18:48:33
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1003
Hex Value: 0x2BB5
Hex Value: 0x727F
Hex Value: 0x807B
Hex Value: 0x7C00
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 32601A9A6D22F9B1A8B-8067
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0251
Revision: BF046001 Serial number: 0434 158112043
Coding: 25B029BF08E12400922808006D2B0CD000C0412F60860000200000000000
Shop #: WSC 124697 483 00190
VCID: 458A5146CCAC7E091D9-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 1621
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 007 1621
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Coding: 010000
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301113600175
Coding: 108104
ROD: EV_VW250ParkiAssis2_VW25.rod
VCID: 3D7A39A6AC7C36C9459-8068
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag014 H09 0020
Revision: -------- Serial number: 003GZ000JDYY
Coding: 003134
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4C9C6462E7C68F41C27-8019
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40590ILP05GBH
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405V0ISD4DHSM
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB40610KOIA80IG
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB405B0KOIA7GM2
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 970 A HW: 6R0 920 970 A
Component: KOMBI H03 0505
Coding: 440A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 346C1C829F36F781BA7-8061
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0251
Revision: BF046001
Coding: 002100
VCID: 70E4D092A3AE8BA19EF-8025
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AD0C2FA8D727171D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660151400
Coding: 010000
VCID: 2952FDF640F4BA69191-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 00788
VCID: 2F6613EEEA10D459C75-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 032 0079
Revision: 01000001 Serial number: VWZ1Z2L3411930
Coding: 01000400020001
VCID: 336E1F9E9238F0B9A3D-8066
End-------------------------(Elapsed Time: 02:40)--------------------------
Re: Polo git coding help
It is not possible with your BCM 6R0 937 087 K (address 09) and wiring configuration of lights your GTI. It is also necessary to have light sensor.
Front fogs as drls
This is not possible in Polo 6R, fog lights can not work as DRLs.
Unless you refer to the bulbs they are beside to the fog bulbs within fog lamps, in this case, make sure you have these bulbs.
Needle sweep
Try this: indicator_celebration
Longman
Drives: Polo 6r gti
Post by Longman »
So what coding mods can be done on the polo gti then ciclo ?
It depends mainly on the equipment installed at the factory or fitted later.
For example, the following link is a tweaks guide with VCDS for the Ibiza 6J, but is almost equal to the Polo 6R.
http://automobiles.fredericbazin.fr/PDF ... s%20EN.pdf
Take a look and then, if possible in your car, make the changes you deem appropriate.
Longman
Drives: Polo 6r gti
Post by Longman »
ciclo wrote:It depends mainly on the equipment installed at the factory or fitted later.
This for the advice
Next question I've fitted a 315 rns headuint which Bluetooth module do I need to work in my gti with the rns 315
