Hi guys,
as title suggests I have fitted cruise control to my Polo 6r with genuine VAG parts but it is not working.
I have activated CCS through Engine 01 - Coding 07 via VCDS but still no joy.
I then did some digging and looked at the Adv. Meas. Values and looked the cruise control values and found that even though the switch on the stalk is 'ON' it says its actually 'OFF' on the Value.
Am I right in thinking the switch may be faulty or some kind of wiring fault?
or is it something that I don't know about on VCDS ?
I would attach a pic of the Adv. Meas. Values to show what I mean. but I cant add any attachments. if you need any more info or screenshots feel free to give me an email at mrkcanning@yahoo.co.uk or pm me on here.
any help if appreciated in advance,
thanks
Cruise Control Retrofit Fitted But Not Working
Re: Cruise Control Retrofit Fitted But Not Working
I have activated it via the BCM but still nothing,
here is the results from my autoscan
Monday,03,August,2015,10:58:46:26102
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: ****ZZ6RZDY00**** License Plate: *******
Mileage: 76170km-47329mi Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 3C 3D 44 47 4B 56
VIN: ****ZZ6RZDY00**** Mileage: 76170km-47329miles
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
3C-Lane Change -- Status: Cannot be reached 1100
3D-Special Function -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
4B-Multifunc. Module -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CGPB) Labels: 03E-906-019-CGP.clb
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 9487
Revision: --H03--- Serial number:
Coding: 00110016002400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MPI02103E906019M 001008
ROD: EV_ECM12MPI02103E906019A_VW25.rod
VCID: 2E5310DF7172B351CC3-807B
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 230224E3216D00B5C42D24E884D700801300
VCID: 020B946F996AE73178B-8057
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 21
Reset counter: 250
Mileage: 71776 km
Time Indication: 0
Date: 2015.06.14
Time: 18:46:59
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1203
Hex Value: 0x2BB5
Hex Value: 0x4A7E
Hex Value: 0x7F7F
Hex Value: 0x7DF8
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 39793383B03C64E9691-806C
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 140122207
Coding: 3CB829BF08A1040000200EC02F2B0CD0F0C041FF60062040200000000000
VCID: 45814F73CCC410091D9-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1621
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1621
Coding: 18BC30
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01X H10 0020
Revision: -------- Serial number: 003GX018CXN0
Coding: 003158
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A9B7C4FEDDAFF71F0B-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405P1C4LIG91J
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405B1D5MSEPC1
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB406317ABOJHOX
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB406917ABO5GLM
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 960 K HW: 6R0 920 960 K
Component: KOMBI H04 0605
Coding: 440801
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3D712793AC1458C9459-8068
2 Faults Found:
13649152 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Date: 2015.04.24
Time: 11:15:40
13635328 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Date: 2015.04.24
Time: 11:15:41
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002100
VCID: 70EFCEA7A3C6E5A19EF-8025
5 Faults Found:
00380 - Special Vehicle Control Module (J608)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:42
01300 - Control Module for Navigation with CD-Rom (J401)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:46
00463 - Control Module for Digital Sound Package (J525)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:46
03590 - Control Module for Multifunction Module
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:46
02849 - Control Module for Lane Change Assistance (J769)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:41
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H04 0605
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADBDCCF8D1A1F71D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584584
Coding: 010100
VCID: 2A5B1CCF459ADF7110B-807F
2 Faults Found:
00464 - Control Module with Display for Radio and Navigation (J503)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 0 km
Time Indication: 0
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 0 km
Time Indication: 0
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change
Cannot be reached
Address 3D: Special Function
Cannot be reached
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6D0DDBEA78BA59C75-807A
Address 47: Sound System
Cannot be reached
Address 4B: Multifunc. Module
Cannot be reached
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
Component: Radio RCD310 004 0119
Revision: 00000001 Serial number: VWZ1Z2M2000558
Coding: 01000400020001
VCID: 35613FB39C2480898D9-8060
End-------------------------(Elapsed Time: 03:18)--------------------------
hope this helps
thanks
www.Ross-Tech.com
Revision: --------
1 Fault Found:
Fault Priority: 0
Fault Frequency: 21
Reset counter: 250
Mileage: 71776 km
Time Indication: 0
Date: 2015.06.14
Time: 18:46:59
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x1203
Hex Value: 0x2BB5
Hex Value: 0x4A7E
Hex Value: 0x7F7F
Hex Value: 0x7DF8
Revision: 0003SH02
Coding: 18BC30
Coding: 18BC30
Coding: 003158
Coding: 440801
2 Faults Found:
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Date: 2015.04.24
Time: 11:15:40
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Date: 2015.04.24
Time: 11:15:41
Revision: BF046001
Coding: 002100
5 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:42
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:46
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:46
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:46
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 67074 km
Time Indication: 0
Date: 2015.04.24
Time: 11:15:41
Serial number:
Coding: 010100
2 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
Mileage: 0 km
Time Indication: 0
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 0 km
Time Indication: 0
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 11250
Shop #: WSC 00788
Cannot be reached
Cannot be reached
hope this helps
thanks
Also tries this, BCM-09-Cent. Elect.---> Byte22 Bit4 activated
3CB829BF08A1040000200EC02F2B0CD0F0C041FF60063040200000000000
Tell me the results.
Did you change the BCM yourself?
Enters the Gateway (address 19),
click installation list,
disables all of the equipment (address) that does not have your Polo 6R to clean autoscan faults,
for example these address:
Do it.
New autoscan.
The correct slot for CCS in your ECU (CGPB) is T121 /69
Do it.
New autoscan.
hi,
I looked at BCM -09 Cent. Elect --> Byte22 Bit4 and it only has
bit 5 Assistant Driving Light(ADL) Active
bi6 6 Interlock Display (Clutch Message) In Instrument Cluster Active
( sorry, cant insert Pictures)
I didn't change the BCM but the BCM in my polo is already capable of accepting cruise control
Ive removed those addresses like you said and this is my new autoscan:
Tuesday,04,August,2015,17:14:38:26102
www.Ross-Tech.com
Mileage: 76210km-47354mi Repair Order:
Scan: 01 03 08 09 15 17 19 25 2E 44 56
VIN: ****ZZ6RZDY00**** Mileage: 76210km-47354miles
Readiness: 0000 0101
Revision: --------
Revision: 0003SH02
Coding: 3CB829BF08A10400002008C02F2B0CD0F0C041FF60062040200000000000
Coding: 18BC30
Coding: 18BC30
1 Fault Found:
03156 - Sensor for Anti-Theft System (G578)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 213
Mileage: 76215 km
Time Indication: 0
Date: 2015.08.03
Time: 21:24:26
Coding: 003158
Coding: 440801
Revision: BF046001
Coding: 002100
5 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:02
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:06
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:06
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:06
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:01
Serial number:
Coding: 010100
2 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:02
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 17:29:51
Coding: 11250
Shop #: WSC 00788
End-------------------------(Elapsed Time: 01:45)--------------------------
thanks
www.Ross-Tech.com
Revision: --------
Revision: 0003SH02
Coding: 18BC30
Coding: 18BC30
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 213
Mileage: 76215 km
Time Indication: 0
Date: 2015.08.03
Time: 21:24:26
Coding: 003158
Coding: 440801
Revision: BF046001
Coding: 002100
5 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:02
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:06
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:06
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:06
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:01
Serial number:
Coding: 010100
2 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 211
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 11:28:02
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 76170 km
Time Indication: 0
Date: 2015.08.03
Time: 17:29:51
Coding: 11250
Shop #: WSC 00788
thanks
No matter that bit 4 of Byte22 not have a description, you can change the bit value in binary box, or copy the full coding from here and paste it before click on long coding helper.
Better with pictures:
First way
the result
or second way
copy this coding
3CB829BF08A10400002008C02F2B0CD0F0C041FF60063040200000000000
Paste here
First way
the result
or second way
copy this coding
Paste here
I have change the bit value in the binary box as suggested and the original '20' changed to a '30' but I havnt got the bit numbers from 0 - 7 down in a line and also made no effect to the cruise control.
I would happily post images of my screen but I cant add attachments.
any other ideas ?
much appreciated
any other ideas ?
much appreciated
01-Engine - codingII - 11463 https://www.drive2.ru/l/6491454/
