Tyre monitoring system reset
Chr15tdi
Drives: 2010 1.6TDI SEL
Post by Chr15tdi »
Hi all
The tyre monitoring system light came on my dash last week and as i knew i was going to change the nearly worn front tyres this week, i just left it and have been driving around with the light on.
Today i have had the tyres replaced and have checked all the tyres PSI's
i switched on the ignition, pressed the "set" button in the glove box until i heard the beep........ But the light is still on and wont turn off....
What do i do now?
Re: Tyre monitoring system reset
Do it again with the engine running. Sometimes it takes two attempts to set.
Chr15tdi
Post by Chr15tdi »
Ah thanks Alex,
Sorted now... I obviously didn't give it enough time... Held the button down before I switched on ignition, then kept it pressed for about 7seconds.. The light flashed twice then went off...
Thanks again.
