bulb out warning light cancelation via vagcom
Have intermittent bulb out warning light on dash.. Comes and goes checked all lights and everything working fine.. Wanted to knw how to cancel this using vagcom coding... Thnxs
Re: bulb out warning light cancelation via vagcom
disable cold diagnostics for [insert light name]
orrrr... check the fault code with VCDS and replace a light that comes to the end of its life
I have this problem too but I don't see any option for cold diagnostics on vcds?
lancslad1985
The BlueGT I have as a courtesy car (get mine back tonight, sigh) has this issue with the xenons. Sometimes when you flash it says the bulb is out when clearly it isn't!
