VDO oil gauges
BioS
Drives: 6n2 GTI
VDO oil gauges
Post by BioS »
Hi guys,
I want to install two VDO gauges.
Ordered these two:
http://www.ebay.com/itm/VDO-Oil-Pressur ... 3f482166ea
http://www.ebay.com/itm/VDO-Oil-Tempera ... 3f53083f03
The gauges will be connected with Greddy oil adapter.
Now, I got a little confused.
Found these two sensors:
http://www.ebay.de/itm/VDO-Druckgeber-O ... 1649500421
http://www.ebay.de/itm/VDO-Temperaturge ... 1645248147
Is 22MM is the standard length?
The sensors suppose to fit without any problems?
Thanks a lot!
Re: VDO oil gauges
I imagine itll fit ok
The only issue I can forsee is the GTI already has an oil cooler, so the filter is already quite far forward. You may struggle with adding another adapter due to the limited space against the manifold and air con compressor
