Polo LED headlights
boj27
Drives: polo gti 6r 2012
Polo LED headlights
Post by boj27 »
Hello,
I am looking at the below for my car:
http://k-seek.en.alibaba.com/product/14 ... _2011.html
has anyone ordered any of these before? I am looking at getting them installed but i dont know how easily they will fit with the car electrically.
any help would be appreciated.
Re: Polo LED headlights
Ah, I've just looked at them and it is only the DRL that are LED and not the main/dip beam - looks like the dip beam is HID.
boj27
Post by boj27 »
yes just the DRL would be LED which is what im after. They look very OEM and wondering if they would work straight out of the box. they come with 2 adapter harnesses and 2 different fuses, i wonder if Ciclo can help me out :D?
without any specification or wiring scheme, the best anyone can do here is speculatiing.
Marjacic
Drives: Polo 6R 1,6 TDI 105 hk Highline
Post by Marjacic »
Have you bought them and installed them?
CNK
Drives: 6R
Post by CNK »
Hey,
Do you know what I need to retrofit full LED headlights from Polo 6C?
I mean this headlights:
I know that this is possible because I saw this 6C headlights in the Polo 6R on: https://www.facebook.com/page.AUTODC/po ... 1765191800
https://www.facebook.com/page.AUTODC/ph ... =3&theater
Do full LED headlights are better or worse than xenon headlights?
Regards! ;)
Yes it is possible. I've done it a few weeks ago.
You will need a new BCM, a lot of wiring and some headlights. It's a lot of work, and I'm not sure they are a lot better than the OEM xenons. Nobody really knows.
Quote:- "are LED headlights better or worse than HIDs?"
Well, I've had two cars with factory fitted HIDs and they were very good. My wife's new Polo has LED headlights and they are okay, I think that HID headlights will disappear as these LED headlights are the way forward especially as far as energy usage is concerned, which suits Stop/Start systems.
Are they better or worse than HIDs? One thing that I've noticed is that because of their design, the "shape" of the headlight "envelope" can be better controlled and so at least the Polo ones get the headlight beams extended as far as the other side of a normal road, maybe on full brightness - which must be an improvement over conventional lighting systems which just tend to have the edge of the weaker part of the beam reaching the other side of the normal width road - I'd like to say that they are as good as HID - that is comparing them with factory fitted HID headlights.
CNK
Drives: 6R
Post by CNK »
iichel wrote:Yes it is possible. I've done it a few weeks ago.
Thanks!
I know, that I have to change my BCM, but could you tell me if retrofit LED headlights is harder than normal OEM Xenons?
Not a lot harder no ;)
CNK
Drives: 6R
Post by CNK »
iichel wrote:Not a lot harder no ;)
Thanks, so I have to start looking for a used headlights in good condition :)
but..
iichel wrote:well the LED headlights have a 14-pin connector and automatic headlight range control so I suspect that it's not a straight swap
iichel wrote:what is sort-of working:
- flash high beam (both dipped and high beam come on)
what is not working:
- dimmed LED for parking lights
- dipped beam (does not go on)
- high beam (dash warning light comes on)
what will have to be changed:
- static cornering light goes to the front fog light
so to find out:
what does the pin T14/14 do? the color is red/white suggesting its a 12V wire terminal 30.
You solved this problem? :?:
Do you have a BCM 7H0 or 7E0? :idea:
I have the 7E0 and it is working perfectly. I did not do it all by myself, I had some help with it.
theddhie
Drives: Polo 6R
Post by theddhie »
iichel wrote:I have the 7E0 and it is working perfectly. I did not do it all by myself, I had some help with it.
Hi iichel,
I am retrofitting my Polo 6C OEM Halogen headlights to 6C LED Headlights.
I have problem the DRL is not working. City Lights, Low beam and High beam works well.
My BCM is 6RU 937 087 M. Does it support for DRL?
I bought 6C0 937 089 B dunno whether it will solve my problem or not.
Thanks in advance.
theddhie
Drives: Polo 6R
Post by theddhie »
Hi iichel,
could you help me with the coding?
Thanks in advance.
I am not familiar with 6C bcm coding. We did it with the 7E0 BCM from the transporter in the Polo 6R. You have the Polo 6C which is completely different.
current:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 092150183
Coding: 7CB02FBF28E3ED0093380FD17CAB9FF0DAC073AF608D3050200000030800
Shop #: WSC 18752 008 00032
VCID: E8D520E01B8D9A5EBC3-80BD
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 231211 05 54 0403
Coding: 0F30AD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF
Component: J387__TSG_BT 003 8611
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K0 951 605 D
Component: LIN BACKUP HO H03 1301
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Coding: 08BC32
