p0441 incorrect purge flow error code
lordvoldemort
Drives: 9n
Post by lordvoldemort »
Hey im having trouble with a p0441 "Inccorect Purge Flow". The purge solenoid has been replaced to no avail. I was wondering if you could suggest what might be the next likely thing/how to diagnose?
Ive got the 1.2 AZQ engine. Help identifying the Charcole/evaporative canister would be great also. As ive no idea where it is in my car.
Regards
Volde
Re: p0441 incorrect purge flow error code
I'm guessing here, but have you tried tracing back the pipe from the solenoid, I would think that the canister is located near the fuel filling area of the car, maybe remove the rear off side wheel arch liner and have a look to see what is wrong. If it is not there it should be inside the front off side wheel arch liner, I'd think that you need to look under both to fully understand/check what is wrong.
Maybe join www.briskoda.net and www.seatcupra.net and ask or search using charcoal canister or something like that. (Fabia MK1 and Ibiza 6L sections)
