Negative Camber
haflidij
Drives: Polo 1.4 2013 6R
Negative Camber
Post by haflidij »
Hey there i have a 2013 Polo with lowering springs 35mm at front and 55mm at the rear. I was wondering how can i get more negative camber ?.
I currently have 16'' on 205/55 tires.
Ricmondo
Drives: Polo Blue GT
Re: Negative Camber
Post by Ricmondo »
Why do you want to alter the camber?
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Re: Negative Camber
Post by Mart!n-GTI-DK »
I'm wondering that too...
haflidij
Re: Negative Camber
Post by haflidij »
Mart!n-GTI-DK wrote:I'm wondering that too...
Yes i would like to have a -1 camber. Just so its showing that they are inwards just a bit.
haflidij
Re: Negative Camber
Post by haflidij »
Ricmondo wrote:Why do you want to alter the camber?
Im just wondering if it would look good or not. Maybe -1 in camber not much more than that.
Nicomati
Drives: VW POLO 6R
Re: Negative Camber
Post by Nicomati »
haflidij wrote:Hey there i have a 2013 Polo with lowering springs 35mm at front and 55mm at the rear. I was wondering how can i get more negative camber ?.
Hi!
You need a set of camber plates!
I've installed one set of brand "ta technix" that permit up to 4 grades of negative camber!
Best regards!
Enviado desde mi iPhone utilizando Tapatalk
haflidij
Re: Negative Camber
Post by haflidij »
Hi!
Best regards!
Enviado desde mi iPhone utilizando Tapatalk[/quote
Hey thanks for the reply so quickly. Is there any way you can link me the set you have ?.
Nicomati
Drives: VW POLO 6R
Re: Negative Camber
Post by Nicomati »
Hi!
Best regards!
Sorry mate,
I bought the product in Vagspeed and i havent link to buy!
If you put "ta technix camber plate" in google must find it.
Regards!
Ricmondo
Re: Negative Camber
Post by Ricmondo »
Is there a measurable gain from negative camber or is it just cosmetic snake oil that reduces tyre life?
Nicomati
Drives: VW POLO 6R
Negative Camber
Post by Nicomati »
Ricmondo wrote:Is there a measurable gain from negative camber or is it just cosmetic snake oil that reduces tyre life?
Hi Ricmondo!
Depending of your type of conduction, if you only have the polo for daily car and you uses it to go work, university or something like that you really don't need this camber plates.
No doubt if you uses the car in trackdays (like me), go to route or simply want to reduce the swing and subviragem you need one set of this!
Best regards.
Ricmondo
Re: Negative Camber
Post by Ricmondo »
So that's a no then!
haflidij
Re: Negative Camber
Post by haflidij »
Nicomati wrote:
haflidij wrote:
Nicomati wrote:
Hi!
Best regards!
Sorry mate,
Regards!
Oh yes i found the website. This is the part but i only see 2 of these. Arent there supposed to be 4 ?.
http://www.tatechnix.de/tatechnix/gx/pr ... olo-v.html
Nicomati
Drives: VW POLO 6R
Re: Negative Camber
Post by Nicomati »
Hi!
Our polo's has the rear axe fixed. You can't get negative camber in it with springs...
Only with a coilovers/neumatic suspension that permit to adjust negative camber in both axes.
Best regards!!!!
haflidij
Re: Negative Camber
Post by haflidij »
Nicomati wrote:Hi!
Best regards!!!!
Oh man that sucks :// . I was hoping to get a bit of negative camber .
Nicomati
Drives: VW POLO 6R
Re: Negative Camber
Post by Nicomati »
haflidij wrote:
Nicomati wrote:Hi!
Best regards!!!!
And you can get it, but only in the front axe Without "traps"...
The truth is that where the improvement of feel to camber in a car with front-wheel drive is on the front axle :)
Regards!!!
