Page 1 of 2
Negative Camber
Posted: Tue Nov 03, 2015 1:39 am
by haflidij
Hey there i have a 2013 Polo with lowering springs 35mm at front and 55mm at the rear. I was wondering how can i get more negative camber ?.
I currently have 16'' on 205/55 tires.
Re: Negative Camber
Posted: Tue Nov 03, 2015 4:41 pm
by Ricmondo
Why do you want to alter the camber?
Re: Negative Camber
Posted: Tue Nov 03, 2015 7:55 pm
by Mart!n-GTI-DK
I'm wondering that too...
Re: Negative Camber
Posted: Tue Nov 03, 2015 10:42 pm
by haflidij
Mart!n-GTI-DK wrote:I'm wondering that too...
Yes i would like to have a -1 camber. Just so its showing that they are inwards just a bit.
Re: Negative Camber
by haflidij
Ricmondo wrote:Why do you want to alter the camber?
Im just wondering if it would look good or not. Maybe -1 in camber not much more than that.
Re: Negative Camber
Posted: Tue Nov 03, 2015 11:12 pm
by Nicomati
haflidij wrote:Hey there i have a 2013 Polo with lowering springs 35mm at front and 55mm at the rear. I was wondering how can i get more negative camber ?.
Hi!
You need a set of camber plates!
I've installed one set of brand "ta technix" that permit up to 4 grades of negative camber!
Best regards!
Enviado desde mi iPhone utilizando Tapatalk
Re: Negative Camber
Posted: Wed Nov 04, 2015 1:15 am
by haflidij
Hi!
Best regards!
Enviado desde mi iPhone utilizando Tapatalk[/quote
Hey thanks for the reply so quickly. Is there any way you can link me the set you have ?.
Re: Negative Camber
Posted: Wed Nov 04, 2015 1:51 pm
by Nicomati
Hi!
Best regards!
Sorry mate,
I bought the product in Vagspeed and i havent link to buy!
If you put "ta technix camber plate" in google must find it.
Regards!
Re: Negative Camber
Posted: Wed Nov 04, 2015 2:42 pm
by Ricmondo
Is there a measurable gain from negative camber or is it just cosmetic snake oil that reduces tyre life?
Negative Camber
Posted: Wed Nov 04, 2015 5:44 pm
by Nicomati
Ricmondo wrote:Is there a measurable gain from negative camber or is it just cosmetic snake oil that reduces tyre life?
Hi Ricmondo!
Depending of your type of conduction, if you only have the polo for daily car and you uses it to go work, university or something like that you really don't need this camber plates.
No doubt if you uses the car in trackdays (like me), go to route or simply want to reduce the swing and subviragem you need one set of this!
Best regards.
Re: Negative Camber
Posted: Wed Nov 04, 2015 7:08 pm
by Ricmondo
So that's a no then!
Re: Negative Camber
Posted: Wed Nov 04, 2015 9:16 pm
by haflidij
Nicomati wrote:
haflidij wrote:
Nicomati wrote:
Hi!
Best regards!
Sorry mate,
Regards!
Oh yes i found the website. This is the part but i only see 2 of these. Arent there supposed to be 4 ?.
http://www.tatechnix.de/tatechnix/gx/pr ... olo-v.html
Re: Negative Camber
Posted: Wed Nov 04, 2015 11:50 pm
by Nicomati
Hi!
Our polo's has the rear axe fixed. You can't get negative camber in it with springs...
Only with a coilovers/neumatic suspension that permit to adjust negative camber in both axes.
Best regards!!!!
Re: Negative Camber
Posted: Thu Nov 05, 2015 1:52 am
by haflidij
Nicomati wrote:Hi!
Best regards!!!!
Oh man that sucks :// . I was hoping to get a bit of negative camber .
Re: Negative Camber
Posted: Thu Nov 05, 2015 7:48 am
by Nicomati
haflidij wrote:
Nicomati wrote:Hi!
Best regards!!!!
And you can get it, but only in the front axe Without "traps"...
The truth is that where the improvement of feel to camber in a car with front-wheel drive is on the front axle :)
Regards!!!
