Auto lights question polo BGT
DKPOLOGT
Drives: Blue GT
Post by DKPOLOGT »
Hello :)
Quite often i see this.
DRL on with low beams. Is this correct?
Instrument cluster also goes op and down in brightness. Example. Grey Day, cluster light on, going thru forest area with overhanging trees, and cluster brightness is turned down.
Should'nt it be the other Way ?
/ *L*
Artimus
Drives: 6C Polo 1.4ACT BlueGT, 7.5 Golf R Estate
Re: Auto lights question polo BGT
Post by Artimus »
No! The cluster lights go dim to remind you to turn your headlights on.
PoloBlueGT
Drives: Landrover Freelander
Post by PoloBlueGT »
Is it possible to fit auto lights to a 2014 blue GT?
if 6R, go here: viewtopic.php?f=62&t=69223
if 6C, not sure...
