offside headlamp
biburybill
- Drives: 2012 6R
offside headlamp
dear members my offside headlamp is not working i have fitted new bulb still not working i cant find a fuse number but think i checked every fuse and all seem ok any ideas please regards Roy .
Re: offside headlamp
Is it just the dipped beam that is not working or is it the whole headlight unit?
check the fuse
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
And no matter how stupid it may seem... Double check the bulb... Triple check if you have too.iichel wrote:check the fuse
sendoc
- Drives: polo match 1.4 (6R) & Toyota Avensis T3
Check both the bulb and fuse for continuity using a multimeter rather than using naked eye.
(some times tiny break in continuity are deceiving)
If both are ok then check the bulb connector for voltage.
Just my 2 cents.
Just my 2 cents.
Fuse 39, or 59. (with multimeter)
Fuse numbers are written on the plastic of the fuse box. Small, very small ...
