Second USB socket?
Posted: Tue Jan 05, 2016 9:52 pm
by CNK
Re: Second USB socket?
Posted: Wed Jan 06, 2016 9:09 am
by peter_dk25
I used this in my Polo 6R:
http://www.doubleapex.co/products/usb_c ... =338115402
But looking at your pictures tells me that you need to buy another USB port with a green connector.
I think it is this one: 6C0035726B - but check with your local dealer...
Posted: Wed Jan 06, 2016 1:43 pm
by CNK
Can I connect this directly into the 12V cigarette lighter?
USB runs at 5V.
Posted: Wed Jan 06, 2016 1:48 pm
by peter_dk25
Read the link carefully - the USB charger kit tranforms 12V into 5V.......
Posted: Wed Jan 06, 2016 5:52 pm
by CNK
So there is no cheaper way to do it?
$69 / $99 + additional USB socket from Polo 6C is a bit expensive
Posted: Wed Jan 06, 2016 9:37 pm
by vc-10
Stick a cheap adaptor in the cigarette lighter socket?
Posted: Wed Jan 06, 2016 9:42 pm
by CNK
vc-10 wrote:Stick a cheap adaptor in the cigarette lighter socket?
Hahah, I think about custom 5V inverter to this USB socket
Posted: Wed Jan 06, 2016 10:12 pm
by vc-10
Pulling apart a USB adaptor is probably a reasonable way of doing this. It will contain a 12v-5v inverter, and they're quite small and cheap I'm sure it could be stashed away under the centre console somewhere. Wire it in to the 12v socket next to it, and connect it to the OEM plug! More involved perhaps, but a USB charger off Amazon is a few quid!
Posted: Wed Jan 06, 2016 11:20 pm
by Dink
Yeah but a cheap cigarette lighter charger
Then rip the converter out of it solder on some wires for input and output (don't forget to fuse the input) then rap in heat shrink.
Then wire that into somewhere suitable then attach output to correct pins on plug thing then away you go.
