Speaker accident
sizey
Drives: 1.2 Polo 2004
Speaker accident
Post by sizey »
Hello everyone, my name is Simon -and am a first time visitor.
Today I managed to drive a pole through the cover of my rear door speaker. With other cars it is usually a case of removing said cover and replacing - however, this appear to be part of the entire door skin.
Any suggestions for a quick fix, other than a new panel.
Thanks so much in advance
Simon
Re: Speaker accident
The speaker cover is removeable - the plastic rivets have to be drilled out then it can be removed.
A new one has to be carefully removed from another panel, then plastic welded using a soldering iron or glued into place
It might be easier for you to get a new panel
