I thought of three possibilities
Pedal box welds failing
Damaged clutch cable
Stiff clutch lever in the box
I disconnected the clutch cable at the gearbox end first, the pedal seemed to move smoothly without any roughness.
Having taken the drivers seat out I then removed the clutch cable and pedal. Here's a photo. I cannot see any cracks in the welds, but am somewhat uncomfortable about the "bloom" around the pedal spindle and adjacent weld, or is this signs of an earlier repair ?
I have measured the clutch cable. It seems to be 1105mm rather than the 1095mm quoted so does seem to have stretched, but I cannot feel any roughness as I slide the sleeve along the cable.
I have tried to move the clutch lever to see if there is any roughness but the pressure is too great to make more than a couple of centimetres of movement.
Any ideas on what the real problem will be. I don't want to just start fitting parts without knowing they are faulty, but equally don't want to start pulling gearboxes out where there is no need.
Help and advice appreciated
