Just want to ask, what are the differences between each BCM.
I'm planning to install front fog lights on my Polo 6r 2010.
My BCM is 6R0937085C and i'm not sure if it's compatible or do i have to upgrade my bcm.
BCM
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Re: BCM
Why not just run the foglights around the BCM???
Not a hard job.
This harness (Without cornering lights)
https://www.kufatec.co.uk/shop/en/volks ... ction_ms=1
And then you need a new light switch that supports front fog lights.
Not a hard job.
Re: BCM
Maybe he wants static cornering lights. For those you need a different bcm. For normal fogs, listen to Martin. In fact, always listen to Maetin. He has this habit of being right
Bcm upgrade to a fitting 087 allows other cool stuff like cruise control, comfort functions and probably other stuff like alarm, rain sensor
- Mart!n-GTI-DK
Re: BCM
It's a burden I have to bear...iichel wrote:listen to Martin. In fact, always listen to Martin. He has this habit of being right
