Auto headlights (after market)
Nlolotte
Drives: Polo 1.2 R-Line TSI 6R
Post by Nlolotte »
Does anyone have any experience with the after market Chinese auto headlight sensor and module
http://m.ebay.co.uk/itm/251555972840?fits=Car+Make%3AVW
I want to pick one up as I can't be fussed with oem hacking and slicing bcm wiring and installation seems to look easy on this one, not to mention is adds ch/lh lights!
I have heard horror stories that the switch doesn't illuminate in the dark? Opinions please!
:D
Re: Auto headlights (after market)
that should work just fine
Nlolotte
Post by Nlolotte »
Will the switch laminate as usual at night?
Yes
Nlolotte
Post by Nlolotte »
Ok sweet!
ashtons99
Post by ashtons99 »
Nlolotte wrote:Hi,
:D
What are ch/ lh lights ?
Willni
Drives: Polo '14 6R, Golf 07' Edition 30
Post by Willni »
:D[/quote]
What are ch/ lh lights ?[/quote]
they're coming home and leaving home lights
really the headlights turn on when you unlock and lock the door for a set period of time from anywhere from 10 seconds to i think 30 seconds
ashtons99
Post by ashtons99 »
Ah yes, I get it now.
ashtons99
Post by ashtons99 »
I've read quite a few threads on these. Can anyone clarify what additional wiring etc needs to be done. I'm guessing it's not as simple as plug and play. Some threads mention wiring into the BCM module, others installing relays. Then recoding through vcds
Are there different versions of these some easier to install than others.
Bigtam
Drives: Polo GTI 2016
Post by Bigtam »
I have ordered 1 will let you know how I get on
ashtons99
Post by ashtons99 »
Bigtam wrote:I have ordered 1 will let you know how I get on
Which one is it you've ordered
Nlolotte
Post by Nlolotte »
Yes please tell us which one you ordered, they look fairly simple. module sits between light switch and cable connector, light sensors sit behind a pillar trim.
Only thing is you don't want to cheap out on it because some people report their auto light switch not lighting up at night (no red illumination on dial)
Bigtam
Post by Bigtam »
Got 1 in the ebay link you have on top of page the page and seems to work OK
ashtons99
Post by ashtons99 »
Bigtam wrote:Got 1 in the ebay link you have on top of page the page and seems to work OK
So no reprogramming of systems required or additional wiring into BCM etc, just plug and play
Bigtam
Post by Bigtam »
Yip just plug and play around a 15min-30min job
