6c headlights onto 6r ?
Leeren666
Drives: polo 6r
Post by Leeren666 »
Just curious, does anyone know if the standard halogen 6c headlights will fit my standard 1.2 6r ? I have damaged a clip inside mine but I Can get a 6c pair on the cheap but don't want to waste time and money I am hoping they are simply plug and play but suspect it may be more complicated ? Anyone ?
DKPOLOGT
Drives: Blue GT
Re: 6c headlights onto 6r ?
Post by DKPOLOGT »
I have put 6c headlights on my bluegt.
Straight swap
/ *L*
Leeren666
Drives: polo 6r
Post by Leeren666 »
We're the original blue gt light the single h4 units ? Large indicator above the small sidelight bulb ?
No H7 units. Only the trendline has H4
Leeren666
Drives: polo 6r
Post by Leeren666 »
Mine has h4 units at present ? Very basic, can I swap them as above ?
Yes but it's not plug and play. You will need to make some modifications to make the high beam work properly.
Leeren666
Drives: polo 6r
Post by Leeren666 »
Is it a big job ? I could maybe manage a bit of basic wiring but anything more in depth is out of my comfort zone :)
I am not sure. I only know a vcds trick for cars with start/stop. For cars with a hardwired system it's a tad more complicated. You will need to re-wire a relay. It's not super difficult...
How it should be done exactly is written somewhere on the German forum.
Leeren666
Drives: polo 6r
Post by Leeren666 »
No problem thanks for helping me decide, looks like a standard replacement for me :) lol
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
Leeren666 wrote:Is it a big job ? I could maybe manage a bit of basic wiring but anything more in depth is out of my comfort zone :)
In German - if you understand? You have to register to se the Pictures:
http://www.polo6rfreunde.de/index.php/T ... post231653
iichel wrote:You will need to re-wire a relay. It's not super difficult...
It is extremely simple (OEM), with our help. :)
Leeren666
Drives: polo 6r
Post by Leeren666 »
Well if the 6c lights turn up at the price I was told then I will be in touch ciclo :)
For anyone who wants to do so.
Once installed the twin headlights (6R or 6C) in 6R non Bluemotion:
with this new wire :)
you have to do this:
example 1 (model year A,B,C): Image
Note: If your 6R is 'model year A' it's possible that the violet/grey wire be yellow color.Image
example 2 (model year D,E): Image
:mrgreen: :mrgreen:
Leeren666
Drives: polo 6r
Post by Leeren666 »
That looks simple enough, I am assuming plugs etc are the same, I'll see which lights they are when they turn up, I now have a sneaking suspicion they are the twin h7 from the 6r will it be the same method to the wiring ?
twin H7 is absolutely plug and play
