Page 1 of 6
6c headlights onto 6r ?
Posted: Thu Apr 21, 2016 8:19 pm
by Leeren666
Just curious, does anyone know if the standard halogen 6c headlights will fit my standard 1.2 6r ? I have damaged a clip inside mine but I Can get a 6c pair on the cheap but don't want to waste time and money I am hoping they are simply plug and play but suspect it may be more complicated ? Anyone ?
Re: 6c headlights onto 6r ?
Posted: Thu Apr 21, 2016 8:36 pm
by DKPOLOGT
I have put 6c headlights on my bluegt.
Straight swap
/ *L*
Posted: Thu Apr 21, 2016 8:45 pm
by Leeren666
We're the original blue gt light the single h4 units ? Large indicator above the small sidelight bulb ?
by iichel
No H7 units. Only the trendline has H4
Posted: Thu Apr 21, 2016 8:48 pm
by Leeren666
Mine has h4 units at present ? Very basic, can I swap them as above ?
Posted: Thu Apr 21, 2016 8:54 pm
by iichel
Yes but it's not plug and play. You will need to make some modifications to make the high beam work properly.
Posted: Thu Apr 21, 2016 8:57 pm
by Leeren666
Is it a big job ? I could maybe manage a bit of basic wiring but anything more in depth is out of my comfort zone
Posted: Thu Apr 21, 2016 9:05 pm
by iichel
I am not sure. I only know a vcds trick for cars with start/stop. For cars with a hardwired system it's a tad more complicated. You will need to re-wire a relay. It's not super difficult...
How it should be done exactly is written somewhere on the German forum.
Posted: Thu Apr 21, 2016 9:07 pm
by Leeren666
No problem thanks for helping me decide, looks like a standard replacement for me
lol
Posted: Fri Apr 22, 2016 5:52 am
by peter_dk25
Leeren666 wrote:Is it a big job ? I could maybe manage a bit of basic wiring but anything more in depth is out of my comfort zone
In German - if you understand? You have to register to se the Pictures:
http://www.polo6rfreunde.de/index.php/T ... post231653
Posted: Fri Apr 22, 2016 6:17 am
by ciclo
iichel wrote:You will need to re-wire a relay. It's not super difficult...
It is extremely simple (OEM), with our help.
Posted: Fri Apr 22, 2016 7:49 am
by Leeren666
Well if the 6c lights turn up at the price I was told then I will be in touch ciclo
Posted: Fri Apr 22, 2016 9:36 am
by ciclo
Posted: Fri Apr 22, 2016 12:35 pm
by Leeren666
That looks simple enough, I am assuming plugs etc are the same, I'll see which lights they are when they turn up, I now have a sneaking suspicion they are the twin h7 from the 6r will it be the same method to the wiring ?
Posted: Fri Apr 22, 2016 12:47 pm
by iichel
twin H7 is absolutely plug and play
