Polo 6R 1.6 TDI with Amarok cluster
Meotje
Drives: 6R 1.6 TDI Style
Post by Meotje »
Hello everybody
I own a 2011 polo 6R 1.6 TDI
Last week Volkswagen installed a amarok cluster and it is working.
But now I'm searching for someone who can modify the eprom to have wheel circumference, braking fluid floater, fuel gauge and pictogram fit the Polo.
Can someone please help me :cry:
Oh by the way, I'm from Holland
polodad
Drives: polo 6r trendline
Re: Polo 6R 1.6 TDI with Amarok cluster
Post by polodad »
Perhaps iichel knows how to help you. If I'm not mistaken, he's also from your country
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
Meotje wrote:Hello everybody
Can you share some pics of amarok cluster on polo ?
I have one question in mfd how door opening will show it shows same in amarok or it gets changed to sedan ?
Sent from my iPhone using TapatalkImage
spacewalker
Drives: Just a VW
Post by spacewalker »
I can help you
contact me
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
The worst is getting to eeprom because the changes are very easy. I can help too. Did you buy the cluster in VW or were you only there to install? I have mine to install but I'm stopped because I can not install the immobilizer and in VW they do not do this to me.
smg_shardul
Drives: Polo 6R
gti16 wrote:The worst is getting to eeprom because the changes are very easy. I can help too. Did you buy the cluster in VW or were you only there to install? I have mine to install but I'm stopped because I can not install the immobilizer and in VW they do not do this to me.
What is eeprom?
I have purchased cluster on eBay it's used cluster
I have requested vw to install let's see what they do.
smg_shardul
Drives: Polo 6R
spacewalker wrote:I can help you
contact me
Thank you
sure I will contact you.
spacewalker
Drives: Just a VW
gti16 wrote: Fri Jul 21, 2017 10:51 pm The worst is getting to eeprom because the changes are very easy. I can help too. Did you buy the cluster in VW or were you only there to install? I have mine to install but I'm stopped because I can not install the immobilizer and in VW they do not do this to me.
I can do that for you inc milage reset
gti16
Post by gti16 »
spacewalker wrote: Sat Jul 22, 2017 1:43 pm
I already went to VW and they do not do the service because the cluster was already from another car.
How can you help me?
gti16
Post by gti16 »
smg_shardul wrote: Sat Jul 22, 2017 3:53 am
What is eeprom?
Eeprom is a component where all the definitions of the cluster are.
To access it is necessary to disassemble the entire cluster because it is located below the central display.
smg_shardul
Drives: Polo 6R
What is eeprom?
We need to change that component?
No the EEPROM is a piece of software.
iichel wrote: Mon Jul 24, 2017 5:00 am No the EEPROM is a piece of software.
EEPROM is actually a piece of hardware, ie a chip or IC, EEPROM = a read-only memory whose contents can be erased and reprogrammed using a pulsed voltage, in other words I'd expect to be able to alter/change its contents without removing it - if VW has allowed for that to happen. If not it would need to get removed and fitted to a jig to get reprogrammed. (Electrically Erasable Programmable Read Only Memory)
You are right. The software is the EEPROM dump. But the chip is actually very writeable, for example all the adaptation channels are saved there (the same ones you adapt per vcds).
It also contains non-modifiable parameters, in this case the module identification, immobiliser keys etc.
In this context, calling the software the eeprom made sense but you're completely right. It's the chip. We change the chips' software.
gti16
Post by gti16 »
24LC64 is the eeprom reference
