Is this likely to be the solder issue on the PCB?
Not sure what other causes there are for this one . . .
01276 - ABS Hydraulic Pump (V64): Implausible Signal
Re: 01276 - ABS Hydraulic Pump (V64): Implausible Signal
100% solder joints
6n2stan
- Drives: 6N2 GTI, Golf GTD + R32, T5.1 BiTDI DSG
Slightly off topic, sorry. My auntie has a 9n with exactly the same fault code. Do the 9N's suffer the same problem? I posted this question on the 9n and got no response
I havent seen it on 9Ns, but its not to say it couldnt be, especially if it was an earlier one as there are some carry over parts
is there a DIY for this knocking around, sure i saw one once
Dan
Dan
