Will a 9n3 front end fit on a 9n? Cheers!
Calrob98
- Drives: Polo 9n 1.2 twist
I love the 9n but I prefer the look of then 9n3 front end and wanting to know if you can put the 9n3 front end on the 9n? Thanks in advance!
geo stronach
- Drives: 2003 polo
Re: Will a 9n3 front end fit on a 9n? Cheers!
I would like to think it would. Bonnet wings heat lights bumper and landing panel should make it work
Sent from my SM-G900F using Tapatalk
It certainly is a personal thing, but I preferred the look of the 9N with its, maybe, M-B SLK look alike front lights?
I never attempted to change wife's September 2002 9N car to a 9N3 car as time went on, waited until time had run out and bought her a brand new 6R 6C in August 2015, and I must say, that 6R 6C does not win any awards for good looks in my eyes, it was just down to sticking with VAG as I have VCDS, you know that you are going to get problems so I find it best to accept that and have a good scan tool to help diagnose them - a bit negative maybe?
Edit:- by the way, I'm probably just trying to get you to think a bit more about doing this that is all! I thought about this when I had a 2000 B5 Passat 4Motion, though in my case, again I thought the B5 front was okay and the B5.5 front has not so good - just like the changes made to Polo at that time, it was the rear lights that I was wanting to change, but that was a "no no" as it would have meant quite a bit of bodywork changing!
