1.2 12v limp mode
Calrob98
Drives: Polo 9n 1.2 twist
1.2 12v limp mode
Post by Calrob98 »
Was driving along as normal and all of a sudden my car started coughing and farting, went into limp mode and now sounds like a really bad misfire, changed the plugs and coils but the problem is still there, any help is appreciated
Calrob98
Re: 1.2 12v limp mode
Post by Calrob98 »
Anyone
To start with, you need to check static timing in case the chain has jumped some teeth, other than that maybe a quick compression check?
