Hi, new to this world as we've taken a gamble and a learning exercise for my son, on a Polo that had a disagreement with a deer: the n/s front wheel has been knocked back and some other cosmetic damage.
Taking measurements from a central point to both sides of the subframe, the subframe appears to be in the right place.
We've just got the arm off & it is not obviously mangled. I noticed that the o/s arm looks very similar. A quick check on Eurocarparts suggests that the part is not handed/one arm does L & R - is that correct? If so we could do a check by swapping them over presumably.
Are there any measurements available anywhere?
Any other nuggets of information in this area would also be appreciated.
Many thanks.
Suspension arms/wishbones
Re: Suspension arms/wishbones
Correct the wishbones are not sided. Only the tie rod ends and hubs are
