Auto Locking on drive away
fivelittlefish
Drives: 2016 GTI
Post by fivelittlefish »
I have a 2016 GTI and I want the doors to auto lock when I drive off.
The stealer has just told me this is not possible if it isn't in my settings already.
Is this true?
Oli3000
Drives: 6C 1.0tsi 110 6spd man SEL
Re: Auto Locking on drive away
Post by Oli3000 »
Pretty sure this is in the setup menu on the radio. It is on my 2016 SEL.
It's not in the set up menu for my GTI but can be enabled;
viewtopic.php?f=56&t=69230
VCDS will let you do this, so maybe try to find a VCDS owner local to you who would be willing to make that change for you for a small amount of money. Most VAG forums do tend to support this sort of activity and you can see where your local VCDS owner is and contact them. I think that I wrote my version of a guide to doing that.
fivelittlefish
Drives: 2016 GTI
Thanks everyone!
green_comet
Drives: 2016 Polo GTI
Post by green_comet »
Simple to do with vcds cable or OBDEleven.
Under Central Electrics-Adaptation-Access Control, activate these three options.
(3)-automatisches Verriegeln bei Geschwindigkeit
(4)-automatisches Entriegeln
(18-Menuesteuerung ZV Autolock-Unlock
fivelittlefish
Drives: 2016 GTI
My VW dealer have said they don't have the ability to customise functions in this way, only look at fault codes etc. They suggested finding someone with an aftermarket setup.
Wow.
So - is there any interest in a database of folks who have the stuff, to do stuff?
I'm in South Bucks and I want my doors to lock automatically when I drive off. Happy to pay the going rate. (whatever that is)
JIC Cracked
Post by JIC Cracked »
Hi fivelittlefish
I have a genuine VCDS cable, not too far from Bucks I can code the auto lock/unlock and other tweaks for a small fee.
PM me for further information.
fivelittlefish
Drives: 2016 GTI
PM'd - thanks!
JIC Cracked wrote:Hi fivelittlefish
Scottjd14
Drives: Polo Match 2017
Post by Scottjd14 »
Hi all looking for someone to do this. Any ideas on cost etc.
JIC Cracked
Hi Scott 8)
I have sent you PM, please check.
