I think these are different from the W5W units used at the front, so before I go off searching the web for a pair, has anyone changed these for Can-Bus friendly units and can point me in the right direction of what type etc. ?
LED bulbs for rear reading lights
Norbreck21a
After going in the wife's car this weekend, I noticed that shockingly, I hadn't replaced the bulbs in the rear seat area roof light
Re: LED bulbs for rear reading lights
yes they are different. they are a festoon light, i believe its either a 37, 39 or 39mm bulb in length.
Dink
- Drives: 2015 GTI
i thought the interior lights did not need to be can bus friendly?Norbreck21a wrote:After going in the wife's car this weekend, I noticed that shockingly, I hadn't replaced the bulbs in the rear seat area roof light![]()
if so i wouldn't use can bus ones as non ones will last longer/run cooler
