Hi Everyone,
Just a little niggle but was wondering hopefully knows how to change this setting.
When I unlock the car from the key only the drivers door unlocks, and i have to double tap to unlock all the doors. However now my key is nearly 7 years old it's a bit dodgy and can take sometimes 5 presses to unlock all the doors successfully... With my dads BMW I could go into the iDrive and change this setting, is there any way to do this with the Polo so all the doors unlock on one press of a button?
Cam
Unlocking my Polo.
Re: Unlocking my Polo.
There is a way to change that, well on current Polos, you should find that option in the MMI - maybe in earlier cars you would need to ask a dealer or use VCDS or Carista to make that change.
skymera
- Drives: 2016 R-Line TDi
You'll find it under
Car > Setup > Opening and closing
Change it from Single Door to All Doors
CGreen98
- Drives: Polo 1.6 TDI SEL
I have the basic MMI I think, it's a SEL model but doesn't do much but show speed, mpg, trip times etc... I can just use buttons on the end of the wiper stalk.
I'm pretty sure it's a Polo 6R, not the facelifted 6C.However now my key is nearly 7 years old
You can change this in VCDS
