Swap rear drum brakes to disc brakes?
RadoX
Drives: Polo 6R 1.4 2011
Post by RadoX »
Hello everyone! :)
Is anyone did such a change? Do you have any guide for this conversion?
Best regards!
Re: Swap rear drum brakes to disc brakes?
i did it already a few times. i don't have a guide, but it is possible and quite straight-forward.
CNK
Drives: 6R
Post by CNK »
iichel wrote:i did it already a few times. i don't have a guide, but it is possible and quite straight-forward.
Wow, You've done a lot of modifications :lol:
Did you changed the entire rear beam axle or only brakes? Theoretically, replacing the entire rear beam axle is simpler and cheaper (if you buy used parts)
On drive2 I found this:
:arrow: https://www.drive2.ru/l/2548655/
:arrow: https://www.drive2.ru/l/1170791/
:arrow: https://www.drive2.ru/l/5773731/
:arrow: https://www.drive2.ru/l/7658591/
:arrow: https://www.drive2.ru/l/454976813135824876/
:arrow: https://www.drive2.ru/l/9007050/
I think it might be useful for you :P It seems to me that in the Polo Sedan brakes are similar to the Hatchback.
well you could opt to replace the entire rear axle but i think it's more work.
you need to do some (relatively) simple steps:
- remove the wheel
- remove the drum
- remove the drum brake mechanism (incl brake lines)
- remove the hub
- remove the handbrake wires
then you mount:
- the dust tins
- the axle
- the handbrake wires
- the brake caliper
- the brake disc
the final step is to bleed the system. this is very important.
and of course, you'll need to update the ABS unit coding with vcds.
it's about three or four hours work, but this way you will not need to remove the entire rear axle. this way it's a job that you can simply do on your own.
you'll be needing some specialist tools:
a brake bleeding device
a 30mm spline (12-tooth nut)
Drum brakes should no longer exist, has no sense. Even my bicycle has disc brakes.
Thank you both for the info!
CNK
Drives: 6R
Post by CNK »
ciclo wrote:Drum brakes should no longer exist, has no sense. Even my bicycle has disc brakes.
So I'm a hipster, I still have rear drum brakes :lol:
I think that the horrible truth is. that on these cars, rear drum brakes are okay! I rather having rear disc brakes, have had them for years on all my cars, even my wife's old and new Polo, but they brakes, while looker better and being easier to service, are not given enough work to do so fowl up and cause trouble! For instance at 12 months old and 8.5K miles the rear discs look rough/grooved/rusty and terrible!
Edit:- anyway I am too old to be a hipster, maybe I am a version of what the original hipsters were based on?
gpeixoto109
Drives: 2013 Polo 6R 1.2TDI
Post by gpeixoto109 »
iichel wrote: Mon Feb 13, 2017 7:57 am well you could opt to replace the entire rear axle but i think it's more work.
- remove the wheel
- remove the drum
- remove the hub
then you mount:
- the dust tins
- the axle
- the brake caliper
- the brake disc
What coding do you need to do in the ABS unit?
Depends on your abs system and current brake configuration
DanGro
Drives: 1.2 TDI with rear disk brakes
Post by DanGro »
iichel wrote: Thu Feb 08, 2018 7:04 am Depends on your abs system and current brake configuration
Today I tried to change that code because swapped the drums for brakes, but I keep getting error 22 on VCDS when trying to apply the code.(changing byte 02. 24->28)
so my question: How did you guys code it? and is there a special procedure for it?
many Thanks!
Luigid
Drives: Polo 6r 1.6 tdi
Post by Luigid »
DanGro wrote: Fri Apr 19, 2019 11:14 pm
many Thanks!
byte 02 -> original 24 insert 28
byte 10 -> original 24 insert 14
Yes the post above is correct. If you adapt the brake size, you'll need to adapt byte 2 to 24 and byte 10 to the inverse of byte 2. That should give an accepted coding.
DanGro
Post by DanGro »
Thanks Guys! the Byte 10 did the trick, I must have overread it in the DIY manual.
Gee40
Drives: 2016 6c GTI (manual), 1982 Mk1Golf GTI
Post by Gee40 »
As RUM4MO has said (and again with no disrespect) they really aren't needed on the 1.4 unless you are planning track days?
Bearing in mind expense and hassle can I ask why you want to do it or what benefit you are looking for?
Luigid
Post by Luigid »
Gee40 wrote: Mon Apr 22, 2019 8:28 am As RUM4MO has said (and again with no disrespect) they really aren't needed on the 1.4 unless you are planning track days?
1.4 gasoline - diesel / how many hp? Surely it is nice to have them especially for the handbrake that does not creak when used but we are talking about spending at least 300 euros if the car has less than 90 hp and you don't always push it to maximum drums are enough
