2015 Polo GTi rear brake scoring noise
1coulthard
Drives: 2015 Polo GTi
Post by 1coulthard »
Had a 2015 polo gti for almost two years. When braking from low speed whether brakes are hot of cold, you hear the rear brakes making a scoring noise as if they are worn out! It's not a skreching noise (metal to metal) it's a coarse scoring noise. Local VW garage has had it twice and say there is nothing wrong - it will bed in! Car is nearly two years old with 17,000 miles! They have also said it is characteristic of the car! Any advice? Thanks
Oli3000
Drives: 6C 1.0tsi 110 6spd man SEL
Re: 2015 Polo GTi rear brake scoring noise
Post by Oli3000 »
Seems really common. Only advice I can give! Mine does it too
Bigtam
Drives: Polo GTI 2016
Post by Bigtam »
Mine too and its a 2016
And mine. Sounds like it does just after I've cleaned the car when there's a light layer of surface rust on the face of the discs, but even when the discs are clean you can hear it at low speed. I've put it down to the brake pad material used by VW.
Dink
Drives: 2015 GTI
Post by Dink »
mine is the same. i have noticed a good 1mm lip on the edge of the disc aswell
might just change out the pads and discs for something else
