2016 Polo GTi air conditioning
1coulthard
- Drives: 2015 Polo GTi
2015 polo gti - every time you start the car windscreen steams up. Been in garage twice, both times they can't see anything wrong, but have topped up air con! Any advice? Thanks
Re: 2016 Polo GTi air conditioning
I have the exact same issue with mine. Every time i get in it steams up, especially on a cold morning. Takes ages to clear the screen if sitting stationary.
Yep
Me too!
I've had new Fabia, Ibiza and Polo's in the last 5 years and all have been atrocious when it comes to condensation inside as well as de-misting. Think it's a common problem with Vw brand.
Me too!
- Robby71
- Drives: 2019 Golf R-Line EVO
Have you checked the pollen filter to make sure it's clean/ dry?
I have always my a/c all the time on my Polo GTI and previous cars and haven't had this problem you and some others have experienced.
As well as a dirty or damp pollen filter being a possible blue cause, damp carpets / mats, carrying damp coats in the car, leaking door / sunroof seals or blocked sunroof drainage pipes can cause interior condensation or misting up.
- bennyboy
- Drives: old 6r GTI , now 6c GTI
I've never had this issue for as long as I can remember with owning cars , but I never use the air con , just the normal fans/ blowers.
Worth running your air con at least once a month to stop the seals drying out and the system developing leaks.bennyboy wrote:I've never had this issue for as long as I can remember with owning cars , but I never use the air con , just the normal fans/ blowers.
yorkshire devil
- Drives: 2015 Polo 1.8GTI
I run mine all the time its the only thing that demists to car quickly. Thats when I notice its not working when its cold
Not a GTI but same car, my wife's August 2015 Polo 1.2TSI 110PS SEL, has, as far as I know, only done this once ( a week ago), and that was after driving maybe 5 miles - stopped to shop for 10 minutes, back into car, started it up, the lower area of the windscreen immediately misted up to a height of maybe 6>9 inches, I switched on the AC and it disappeared quickly! Too many Skoda Fabia owners have been complaining about this since the latest Fabia was launched, some thing must be wrong with the cabin ventilation in these Fabia/Polo/Ibiza models - also there seems to be too many complaints about the general "quantity" of warm air being supplied even after the temperature indicator is up to the normal level! I have to accept that my wife is correct when see makes this comment, I tend to deliberately switch the cabin fan off until the coolant temperature is up to normal running level - normally the windows stay clear up to this point with only two of us in the car.1coulthard wrote:2015 polo gti - every time you start the car windscreen steams up. Been in garage twice, both times they can't see anything wrong, but have topped up air con! Any advice? Thanks
Her Polo has Climatronic or whatever auto air con gets called in these cars.
