Fuel tank flap won't open...
janski
Drives: 1.2 SE 12v
Location: North Manchester......Ramsbottom.....yes, its a real place, not made up or owt!
Post by janski »
....9N 1.2 SE 5 door. Its the central locking model. Did a search on Google and on here with little information.
Has anyone had the problem and sorted it?
Please help?
j :(
Re: Fuel tank flap won't open...
I think that all the VWs that have this function use a similar system, so maybe extend your search on Google, I think that what has happened is that the release solenoid has failed or stuck, so the plastic flap gets locked shut. So, I think that basically you will need to remove the inner boot trim and see what you find in there - you should be able to grab the end of that lock and pull it to release the filler cover. Some Audis, if not all, I think, have a strong nylon "emergency release" string to make that problem easier to get round. I've made a note of this string part number, but not got round to ordering one in - to fit to my wife's August 2015 Polo, her September 2002 Polo never had a problem with that function over its 13 years with us.
Good Luck! Maybe use "Golf" instead of "Polo" in your Google search.
janski
Drives: 1.2 SE 12v
Post by janski »
Cheers RUM4MO,
Did sort it out, took out the trim bit where the rear seat belt goes through/where the parcel shelf sits. The actuator for the flap lives there. Took the actuator out, problem solved for the meantime.
j :)
