Fitting Pioneer SPH-DA120 to 2012 Polo 6R
Roh4nms
Drives: 2012 Volkswagen Polo 1.2 6R
Post by Roh4nms »
I've just bought my first car and I wanted to get a radio compatible with my iPhone so I bought the pioneer sph-da120 and I was wondering if someone could give me a few pointers to fitting it...
It has all the original cables however I was wondering if I will need a different adapter because I have the rcd210 currently fitted in my car which means it has a quad lock adapter... also I read about a radio adapter? any help would be greatly appreciated.
Thanks,
Rohan
Re: Fitting Pioneer SPH-DA120 to 2012 Polo 6R
You'll need a fitting kit which will have a surround to adapt from the custom VW radio shape to standard double din, a quadlock to ISO adapter (which will need tapping into an ignition live unless you get an intelligent one) and an aerial adapter lead to go from fakra to the banana style connector
Roh4nms
Post by Roh4nms »
Ok a fair bit more than I realised... thank you :)
Roh4nms
Post by Roh4nms »
alexperkins wrote:You'll need a fitting kit which will have a surround to adapt from the custom VW radio shape to standard double din, a quadlock to ISO adapter (which will need tapping into an ignition live unless you get an intelligent one) and an aerial adapter lead to go from fakra to the banana style connector
Do you have any links to products because there are thousands and I have no idea which ones to get..
Thank you again
https://www.ebay.co.uk/itm/181160802641
You'll need to connect the red wire to an ignition live, the orange wire to an illumination cable (grey with blue stripe) and the aerial amp wire into the pioneer aerial wire on the loom
Roh4nms
Post by Roh4nms »
alexperkins wrote:https://www.ebay.co.uk/itm/181160802641
I'm such a newbie So I really appreciate all the help. How do I know this will fit my vehicle since it's says it's for a VW golf rather than a VW polo?
The mk5/mk6 golf and the 6R polo have the same radio design :D
Roh4nms
Post by Roh4nms »
alexperkins wrote:The mk5/mk6 golf and the 6R polo have the same radio design :D
Thank you again :)
It came with this cable but I simple assumed it would not fit a VW as I have an rcd210 which has a quad lock on it.. Image
Am I wrong in thinking that or do I definitley need a new adapter?
So, that cable goes into the back of the radio, then the adapter loom that comes with the fascia kit plugs into that :)
One more question - do you have steering wheel buttons?
Roh4nms
Post by Roh4nms »
alexperkins wrote:One more question - do you have steering wheel buttons?
Ok thank you. I'll buy the kit now and should be with me for Friday so I'll try fitting it on the weekend.
I don't unfortunately but I'm hoping to get around to retrofitting the multifunction wheel in the future depending how this goes. :)
Roh4nms
Post by Roh4nms »
alexperkins wrote:So, that cable goes into the back of the radio, then the adapter loom that comes with the fascia kit plugs into that :)
Is this kit going to work as well because it comes with faster delivery?
Sorry for the barrage of questions I don't have a clue what I'm doing [emoji23]
Thanks again
If you want to be able to use a multifunction steering wheel in future I suggest you get this kit instead
https://www.ebay.co.uk/itm/272116816686
This requires no extra wiring changes and includes the adapter to make the steering wheel work with the radio
Roh4nms
Post by Roh4nms »
alexperkins wrote:If you want to be able to use a multifunction steering wheel in future I suggest you get this kit instead
I've just had a look online and it'd probably cost around £400 to get a multifunction steering wheel so I'm not sure how far into the future this mod will be....
That kit is the easiest by far to install in any case, but otherwise if you are not bothered, get the first kit I sent
