Gearbox no 5th
Misfit
Drives: 6n2 Gti 1.6 16v arc
Gearbox no 5th
Post by Misfit » Thu Jun 01, 2017 12:37 pm
I've lost 5th gear, I first thought gear linkage which is a bit worn so tried to select 5th from under the car with the linkage removed, you can bring the clutch all the way back up and it doesn't bite. I'm thinking either gearbox is dead or just 5th. The box is an etd.
I have another gearbox but it doesn't have the lower 2 mounting bolts to attach to the engine. Will this fit? I will get the code for the box and update.
Misfit
Re: Gearbox no 5th
Post by Misfit » Thu Jun 01, 2017 12:44 pm
Misfit
Re: Gearbox no 5th
Post by Misfit » Thu Jun 01, 2017 6:24 pm
The gearbox on the right is dqw code
Drives: 91 Golf GTI, 01 TT 225, 67 Q7
Re: Gearbox no 5th
Post by alexperkins » Fri Jun 02, 2017 1:49 pm
No, the GTI requires a GTI gearbox as it has different mountpoints. Completely different ratios and diff too
You are best to get the existing box rebuilt
