Hi All
I'm seriously considering a Stage 1 Remap for my 6c manual GTI and wanted to know if anyone can confirm the max torque rating for the clutch and gearbox as I don't really want the hassle of a slipping clutch etc. Although I'm not particularly brutal with the clutch, equally I'm not prepared to drive it like Miss Daisy by only apply full throttle past a certain amount of revs to protect the clutch, as this defeats the whole point of remapping
Max Torque Rating on Manual 6C GTI
- Drives: 2015 GTI
Re: Max Torque Rating on Manual 6C GTI
seems revo was worried with a stage 2 map but apr don't seem bothered
the box is rated for 350nm but the way vw are you could probably shove about 500 through it
the clutch on the other hand would probably handle it just how long it would last
- Drives: Pure White 6C GTi 3 door manual
Gearbox is the MQ350 same as used in the Golf R and many others.
The box is v strong....the clutch is the weak point but it'd take a stage 1 quite happily....but I wouldnt want to push much more than 300lb/ft through it.
- Drives: 2015 GTI
seeing the facebook post by JBS auto designs
someone has a polo with 380 bhp and 370 lbs/ft so i guess it can take a bit
now who wants to buy a kidney
